Building the Ultimate B2k Beast
S
SurfnSun
I was thinking that if I was to build the turbo motor of choice here it is........
World Products "Motown Race Block" (4bolt splayed 4.00 bore)- $1900
SCAT lightweight 4340 Forged Crank 3.48 stroke- $1200
SCAT(or comparitive brand) H-beam Forged 5.7 Rods- $445
SRP Low compression pistons -24cc 8.2:1 compression w/ 76cc heads $500
AFR 195cc SBC Street Head L98 plug angle $1924
AFR Hydra Rev kit- 179.00
TPIS or AZ Speed Marine --Custom grind cam $500????(a tad more duration and lift on exhaust side.
Grand Total = $6648
ADD the TPIS Runners and Base that are in the garage. Turn up the wick to about 13lbs of boost.....and get new tires :D
So what do you guys think?
C
callaway95
More Horsepower.....nothing wrong with that at all.....
9
90Callaway
I think you should worry about getting the car first! Then you can call Ed at AS&M and he'll tell you how to build a strong TT. Although, you have a good list already.
S
SurfnSun
ouch! :eek: i did put an if in the first sentance :D
We'll see, getting laid off has been pretty rough on me, I only make about 1/2 as much as I used to. :(
9
90Callaway
Hey, nothing wrong with planning for the future. Just trying help you with priorities! :D Email me offline and I'll tell you about the latest completely unnecessary car that I purchased.
Maybe by the time you're ready I'll have mine to 600hp/800ft.lb. and you can just copy mine. ;)
EricVonHa
Suburbia Phila
'93 6-Speed & '87 Callaway
You probably saw the post on the Vette Forum about the "HeaderDesignCompany". I asked if they would design/build header/turbo/intercooler plumbing packages and he kinda gave a nod. I've heard that all this plumbing is beyond THOUSANDS of dollars from design to installation.. gotta add some more bucks to the equation there!
S
SurfnSun
This was just an idea for an existing turbo car ie the long block
rkreigh
Alexandria VA
I'm trying to build a twin turbo ZR1. any help you gents could provide with pipe benders, and expert tuners would be appreciated. I have done most of my posting on the CF. but I need to get more input.
email me or post with any thoughts.
thanks. ron_kreigh@hotmail.com
stuckatcuse
Syracuse
Grand Total = $6648
Some people on thirdgen have had bad luck with scat cranks. There are better brands out there...
