- Joined
- Aug 31, 2003
- Messages
- 49
- Location
- Northern Virginia
- Corvette
- 1961 Roman Red Roadster, 1964 Riverside Red Coupe
Finally got around to the exhaust and found the mufflers had 2 1/2 inlets and 2" outlets. Is this correct? Should it be 2 1/2 in and out. Engine is the standard 327 300.
Documentation shows them purchased from ZIP in 1988 but the ZIP customer service guys were not much help. :confused
Also on the Carter AFB carb, the choke is sticking. Pulled it apart and the spring and shaft appear to be in good shape. The front butterfly shaft is OK also. Any suggestions other than just replace the choke.
