S
Sams '66
What are the steps?....looks a bit crowded in there.......do you try to go in through the glove box? Radio panels?
thanks!
thanks!
IH2LOSE said:When I was working on my stereo system I went in by removing the side panel on the passenger side.glove box liner,and then the clock.It give you all the room in the world.clock is held in with clips(use caution removing the clocks light bulbs you kinda have to SNAP/TWIST The bulbs out) dont just pull on the wire.and the speakers is held in place with 4-5/16th nuts.What are you doing for a replacement speaker?
