Is it possible to get the vent-window glass out of the support without drilling rivets.
I want to replace the weatherstrips.
![door-vent-window-500.jpg](http://www.computersupport.ca/Restoration/door-vent-window-500.jpg)
On a convertible I believe so. But on the coupe, I'm sorry to say no as best as I recall. I've done both, and as best as I remember, the bottom post on both the coupe and the convertible passes thru the rubber weatherstrip. The only way to get the frame out on the coupe is to remove the upper rivet and pull the frame upward after unbolting it from the regulator. The convertible upper post is different, as I recall can be released by dropping down the vent window assembly enough to disengage it.67HEAVEN said:Is it possible to get the vent-window glass out of the support without drilling rivets.
