I already had a Summit A/F gauge when I decided to replace my center console gauges (except for the fuel gauge). I went with inexpensive (cheap?) Sunpro gauges which I bought for $30 which included the voltmeter, oil pres, and water temp.
Here is a pic
The install was real easy and the only tool I used was a dremel. The console is basically 4 pieces:
Metal Outer Bezel
Lens
Metal gauge rim - This is what you see just surrounding the gauges
Metal backing plate - This is what the gauges bolt to.
First, I cut up the metal backing plate so that the new gauges would be able to "stick out" from behind them. If your just using the clock mount, this is not necessary as it is already open for that location.
The 2 1/16" gagues were just too big to fit in the metal gauge rim, so I took a dremel to it and ground just enough for the gauges to slip in with a little bit of encouragement. The gauges fit snug enough to not need any other type of mounting. At this point, the gauges (except for fuel) are all in the metal rim.
Because I wanted to keep my fuel gauge, I had to cut up the lens to fit such that it was only in front of the fuel gauge.
Then, I put all of the bezel pieces together just as they were before.
