dutchboy6804
The hood on my 81 is low in the middel on the front . How do I adjust this.
I don't recall there being an "adjustment" for the center front of a C3 hood. If the front of the hood is low but the corners are at the right position, it may be that the panel is warped or damaged. Or it may be that the car's front body work is faulty, ie: there's nothing wrong with hood but the center of the nose is at the wrong height.
Is it the original hood or an aftermarket replacement?
Has the nose ever been repaired after collision damage?[/QUOTE
Hib Idon,t know the answer to either of those questions ,buy will dig deeper into the body . hood does seem to be a bit low along the sides .
...When I repaired my 70 after an accident, there was a rod that adjusted the surround panel to line up with the hood...
