C4-93-LT1-6 sp IAC Question
Jack W.
Elkton, MD
1993 Torch Red LT1 6 sp
I am in the process of cleaning the throttle body (dirty ain't the word) and have removed the IAC. Looks like there is (well-worn) teflon tape on the threads, and I found a sliver of it in the chamber. Is the tape (or whatever it is) needed when I put the IAC back in? If so, what exactly should be used?
Thanks again,
Jack W.
To which threads are you referring - the bolts that hold the throttle body to the plenum? :confused
You really don't need the teflon tape, or any sealer for that matter, but it was probably used to prevent seizing when you tighten the bolts. ;shrug
