pepeancon
New member
[FONT=verdana, geneva, lucida, lucida grande, arial, helvetica, sans-serif]hello everyone, I finished installing a new Jensen VX6020 nav system into my 1992 C4 LT1, new re-wired cables to all new 4 speakers, I used the adapter from "Electronics Metra 70-1856 Radio Wiring Harness" everything was working fine after the installation, including dash lights, but since the adapter didn't have an Illumination cable for the new radio I end up using the cable connected to he original radio unit grey/black stripe (dimmer light) it had power and dimmer was working I tested, then I attached it with the Illumination cable from new the radio VX6020 and right after that my internal dash lights were gone? something blew-up no more orange lights for the night driving, dimmer doesn't work either, the Cluster lights are fine and the dimmer works fine with the cluster, but all orange lights outside cluster are gone (a/c buttons, gas/trip, etc.. ) are gone, but only in that side, the driver door amenity lights works fine with the dimmer, I disconnected what I did with grey/black and illumination cable from new radio and has no more power as before and dimmer light doesn't work. I think something blew up because there is no more 12v power on the original grey/black dimmer cable that I used. [/FONT]I checked the fuses on the right side panel and they all look fine, where else can I check, please help! thanks.
