Help! C4 clutch pedal
  • Thread starter Thread starter VETTE 40
V
VETTE 40
Hi I have a 1993 LT1 6spd. My car has been sitting for one month, I dont drive it much, when i got into it today I noticed I lost about 90% of my clutch pressure. The clutch was working perfectly the last time the car was used. Did something seize up? thanks....... Frank
Just a guess on my part but you may have water that has condensed in the hyd clutch. Check to see if there is a fluid leak on the clutch fluid hose from the clutch master cylinder to the clutch. An air leak could cause the same problem. As you say the car is stored a lot which is an invitation for Mickey or Minny mouse to take up residnece under your hood. If they have they will be looking for building material for their new home.
mickey and minie
Thanks, I think you may have hit a nerve. I have had previous mice damage. I will take the car in for service. Thanks.............. Frank
