I have just purchased a '96 LT4 that has had the water pump replaced. The previous owner had said the water pump was leaking so he had it replaced. The dealer work order even stated that they "cleaned the area as well as possible". When I put it up on my lift there was a fair amount of oil/antifreeze built up on the front of the oil pan.
What is the best/safest way to clean the engine bay on a C4? I have been told not to simply take it to the car wash and wash it down because getting the Opti Spark wet isn't a good idea. There is limited access even from under the car so I am perplexed on the best way to clean things up.
