C4-warning alarm-ign and lamps
  • Thread starter Thread starter whsteele@bellsouth.net
W
Where is the "warning alarm" module located in dash of 1993 C4? Even dealer not real sure. It is the module that sounds when lamps or ignition key is left in.
Need your advice or perhaps a diagram. Already look inside both under dash areas. Thanks.
If the chime module is the same on the 93 as it is on the 92 it is located directly behind the driver instrument control. It is tucked away under the dash.....not easy to get to. Your local chevy dealer should be able to pull up a diagram of the dash area showing where it is.
