Please let me know if you have one for-sale like this!
Thanks,
6 Shooter
6 Shooter
The wheel size should be stamped on the back side somewhere!Junk - They said the rim's diameter is 18.5" and the tire is 10" wide.
I'll ask them again about wheel width if the tire width is not enough.
THX - D
6-Shooter -
Before you toss that rim, I'd suggest you pull the center cap, and take the emblem out - it's held on by two speed nuts (and perhaps a little adhesive).
Yes, that one might be scratched up, but hang on to it until you get lucky enough to find new emblems - they're pretty scarce, and I'd hate to see you toss that one in the trash, only to find out you can't replace it later!
(I've been looking for them)
We ever get a wheel size??:confused...I'm pretty sure my niece/brother will remove the center cap and put it on their new/used wheel.L8TR - D
OK Shooter, Thats a 88 year modle wheel,Mine are defenetly 89's!!T17x9.5J Left Hand 9/27/87
Thanks,
Dwayne
OK Shooter, Thats a 88 year modle wheel,Mine are defenetly 89's!!I'll call my wheel man tomarrow and see if he can tell me if the offset is the same!! They changed the off set on them in there somewhere!!If there the same off set and use the same center cap,mine should work!!
Later . . . . . .
6 Shooter
