C
Carson
I just installed a need Hurst in my 2000 c5. When I remover the stock shifter, there was an L shaped alignment pin at the front of the stock shifter. The Hurst does not have a slot to reinstall this alignment pin. Everythings works fine now, but I was concerned about long term problems if the pin is not used. Also is it possible to get a new plastic bushing that goes around the knob at the base of the hurst shifter where it connects to the transmission linkage rod. I'm think mine has a hairline fracture. What is the gm parts number
I love the shifter, the 2/3 shift is impossible to miss!!!!
