Hi Paul, I appreciate your input in this thread. While many folks like to use the term “gel cell” interchangably with "AGM," the fact is, those terms describe two different technologies that should not be confused with each other.The “G” in AGM stands for “glass,” not gel. While it is unlikely a consumer would ever find a gel cell battery to use in their automotive application, if they did, they'd have a battery with very narrow charging parameters that could be damaged by traditional lead-acid battery chargers. This also becomes problematic for owners of battery chargers with “gel” or even“gel/AGM” charger settings, as those settings may not fully-charge non-gel batteries and could damage them over time.
Our RedTop batteries are considered SLI(starting/lighting/ignition) batteries and are not designed or warrantied for deep-cycle use. Our YellowTop batteries are designed and warrantied for both starting and deep-cycle use and are generally considered “dual purpose” batteries in that regard, as most folks would not consider using a traditional deep-cycle battery in a starting application.
We haven't offered pro-ration on our warranties since 2009. Even at that time, the free-replacement period for the RedTop was (and still is) 36 months. The free-replacement period for YellowTops is also 36 months. If a consumer buys our Digital 1200 Charger from us at the same time as a 12-volt battery purchase, the free-replacement warranty is extended an additional 12 months. There are many other brands and manufacturers in the market who offer free replacement warranties in excess of 30 months as well.
While the GM unit may be able to test accurately down to 10 volts, what happens below that level? We routinely see warranty returns that are deeply-discharged down into the single digits, but work fine, when properly-recharged. A simple $10 voltmeter will assist owners in understanding the voltage level of their battery.
While I'm glad you and I both agree that alternators should not be used to charge batteries, I think “idiotic” is a strong term to use for people who do that, some of whom may have been in your audience. I routinely come across folks(Corvette owners and non-Corvette owners alike), who believe it is good practice to periodically start and idle their stored vehicle as a way of keeping their battery charged, when the opposite might actually be happening. I don't consider those folks to be idiots, just uninformed as to what is really going on with their battery and charging system.
This is sometimes perpetuated by people working in the industry, if they jump-start vehicles and tell the owners the battery should be fine after they drive their car for awhile. That happened to my neighbor last week, when his mother-in-law's SUV had a battery discharged down to 5.4 volts and roadside assistance came to his house to give him a jump-start. They told him to let it run in the driveway for 15 minutes and the battery would be fine- it wasn't.
Jumper cables and jump-boxes are the electrical equivalent of a one-gallon can of gas. They can get your vehicle going in an emergency situation, but they shouldn't be relied upon to correct the underlying issue. If people drop a gallon of gas into an empty tank, they'll probably be looking for a gas station as soon as they get their car started. The same should be true for people looking to fully-recharge their deeply-discharged batteries. If we could get consumers to understand just that aspect alone of batteries, you and I would both likely be dealing with far fewer battery-related issues.
My apologies on missing your mention that batteries should be accurately tested prior to being put away for storage.
Jim McIlvaine
eCare Manager, OPTIMA Batteries
OPTIMA® Batteries (optimabatteries) on Pinterest
