Clear bra review
This weekend, I had a chance to go over the application of the clear stuff in more detail that I had done by Autotrim Design near home. Cost was $301 installed. I have a Medium Sprial Gray color 04. The application is incredible. You cannot see this stuff virtually at all. You have to feel an edge to realize it is on. No bubbles to speak of, it laid on perfectly. They did run it across the Commemorative pattern of striping that I did in Copper and with a Blue edge line, instead of trimming the pattern in the package, but they assured me that the striping material is so thin compared to the bra material that the bra material would lay down over it with no problems. I will see how that goes. I did it in reverse on my 300M, the bra went on first before I even thought about doing a racing stripe, and then a year or so later I added the striping over it. I had an issue after that about 3 years down the road at the point where the materials intersected. They re-did that area at no charge. They say it will not happen the way it was done this time with the thinner stuff underneath the tougher bra material. I would try to post pictures, but it would be a waste of film, since you can't see the stuff.
