Video: C5 Corvette Horn Fix 2 of 2
Site Administrator
Staff member
Administrator
New Hampshire
1990 Corvette ZR-1
  • This is the second of two videos showing how I fixed the horn on this 1999 Chevrolet Corvette (C5) with the tilt steering column. This shows the assembly of all of the components of the steering column to replace the cancel cam, the horn/airbag assembly and the two-piece column shroud. The first video shows the disassembly and the repair of the horn membrane. I make no claims about the correctness of this procedure. I'm just showing you what worked for me. This is now back together and working fine. If you've got something to add, please let me know via PM with any links so that I can add them to this description. For other comments, please leave a message in the comments section below. This is my first attempt at a video to post to YouTube, so please be understanding of that fact while commenting.
I have the same problem, need to replace the horn diaphragm, but I cannot access your videos. Says the administrator won't let me. Can you re-post??
