THe Psycho is acting up again and the dealer can't find the issue.
Symptoms:
Left door controls go dead and LDCM looses communications. Your are able to get the left door controls to light up by swinging the door open back and forth. Now you can't find fault. Connectors down near left lower side under instrument panel are tight.
Second thing that has happened is massive light up of faults on instrument panel including no communications to LDCM, PCM, HVAC, etc. Temperature, pressure, and gas gage go dead. Reduced engine power warning come up on DIC. ABS and TRaction control lights eluminate. No actual average MPG reading shown on DIC. I could not notice any reduced engine power.
If you turn off ignition, faults will reset. I did notice when I went over a bumpy road the faults were able to be reset and the gauges came back.
Anybody have any ideas how to the gremilins from the Psycho?
Symptoms:
