Check your handbrake lol
Ya know, maybe a few plug wires are loose also!
Same here, only mine doesn't have one of them thar shifter thingies, it's an automaticNot sure what to make of this...
My 6-speed has no problem breaking traction in second gear. It throws my head back every time!
For what it's worth, my '96 LT4 with 80,000 miles is strong. The motor is stock with 4.10 gears and a catback exhaust. It's been dyno tuned and runs mid 12's in the quarter at 111 to 112 on drag radials. Here's a timeslip. It was 84 degrees when I made this pass and I bumped the rev limiter in the top of 2nd gear.
[/URL][/IMG]![]()
Thanks. 13.2 @ 107 is not too shabby. My car dyno'd 305rwhp and 306rwtq. I think the big thing helping my e.t.'s is the gear. Best mod for the buck on an LT4. I just installed a Meziere electric water pump yesterday and I'm headed back to the track this weekend. The car feels stronger now and with the cooler temps, I think a 12.4 is in the cards.Pretty impressive time!:eek My best with my LT4 is 13.2 @ 107. Track elevation was approximately 890 ft above sea level, Goodyear Eagle GSC’s @ 30psi. I’m bone stock all but for a K&N air filter, 52,000 miles.
I’ve never had it dynoed but would expect it to be in the high 290 to 300 hp from what I’ve read over the years. Only C5 I’ve run against was a 2003 Z06. He ran a 12.5 @ 113... he had just over 500 miles on his car.
B17Crew
Hey...I had a '90 Coupe as well before my '96. Good minds think alike.Welcome Jonescap!
Great times there. I am eventually going to swap to the 4.10 gears in mine. For what its worth mine bone stock dyno'ed 308rwhp and 314 rwtq. I've added a few mods (LT headers, exhaust, CAI, electric H20 pump, Granatelli MAF) when I went back in Aug. it dyno'ed 298rwhp 309rwtq. Just goes to show how important a tune is. My A/F ratio was 11.5, I need to lean it out a bit and re-dyno. I was shocked that I lost 10HP and 5 ft/lbs by adding the headers and less restrictive exhaust. The temps and humidity levels were almost the same for both dyno sessions so I ruled that out.
What kind of times are you running with that LT4?Man this thread has somein it. Let's stop talking and start lining up! Who lives in or around tampa with a C5??
I dynoed my then-new '98 vs. my friend's '96 LT4 CE on the same day at the same dyno in 1997. Guess who won?
We both did. He pulled 298hp, I pulled 296. BUT - he pulled 305ft-lbs, and I pulled 310.
I'm the 'Jason' that did the dyno run with Dave that day, many years ago. Back then, I harassed Dave to no end, telling him he bought a slug, and made a mistake. But, my mind was changed after spending time in his car. And now I agree with everything Dave's said. I've owned both an LT4 and an LS1. Both engines are superb, but superb in a different way.
The LT4 has that raw, kick-you-in-the-butt torque. Now. Not now, but RIGHT now. The torque curve is very ideal in that it's flat as a pancake, therefore making the throttle response very predictable. And because of that instant throttle response at any point in the rev range, it makes the engine seem more powerful. It isn't.
The LS1, on the other hand, has a slightly weaker lower end, which makes it feel a little sluggish when compared to the LT4. But, it clearly makes up for this lack of low-end when it hits the mid-range. It is here where the LS1 shines and really shows its stuff. And it makes the engine feel like it's more powerful. It isn't.
Truth be told, the LT4s were all sold as 330HP engines, and were terribly underrated. They were all putting out a good 340-350 HP at the crank. So are the LS1s. In the end, it's a tie, with each engine shining in a certain part of the rev range.
I miss my LT4. Dearly. An auto writer once said (I'll paraphrase here) "Second gear with a Chevy small block is one of the most wonderful gears every invented. It starts at 0MPH and ends north of legal." This was made more apparent with the LT4 and the ZF.
However, the LS1 showed its stuff on the road course, where I (and my 99 C5) spent a lot of time. The mid-range grunt kept me far ahead of everyone else on the track. And the valve train whine that's evident on all LSx engines was an intoxicating sound. But you had to listen for it.
This is a comparison that will never end. It started in 1997, and seems to be as strong and fiercely argued as is was almost 10 years ago. That, my friends, is testament to both engines, and just how wonderful they are. I mean, come on... they're both small blocks. What more needs to be said?
jas (now LS7-powered.. >)
