will try, the engine has a loss of power like a plug stops firing intermittantly under hard accelerationCould you be more specific what you mean by skip?
If you need help retrieving codes you can find all info on tech center pages. Regards, Zig.
Actually, if it runs fine when it's cold then you have a sensor issue once it starts running closed loop. Check to see if you have any codes before spending the money on an injector flush. O2 sensor perhaps? I had a similar issue on my C4 that was an O2. Check for codes first.
Leon
