Jimmie,
I think the pics may have been from my post (link below).
It is relativly easy to replace the cover. Remove the air filter and locking clips for the cover. You then need to pull the cover toward the engine to get the two mounting pins off of the two rubber gromets on the cover. There is a fair amount of effort to slip the new cover in and force it over the ridges on the main air box at the bottom edge and then pushing the rubber grommets back over the two pins. I also put in a K&N filter which comes with a "peel and stick" gasket which you need to put in with the airbox cover removed to get access to where it needs to go.
I took the car out and noted an immediate change when I got on the throttle with these two changes. My 12 year old noted the louder air intake and I noted a bit more response with little effort or cost. Worth the effort for both in my opinion and I have a liftime filter now as well.
Regards,
Bob M.
My airbox post:
http://www.corvetteactioncenter.com/forums/showthread.php?t=65367
