C
caseyk
:confused I experienced a problem yesterday with my driver's side window.I took the top off and rolled the windows down,I noticed a scraping type noise coming from the driver's side window.I attempted to roll the window back up up and it would only come up about a 1/4 of the way. I took the door panel off along with the speaker. I looked inside the door and tried to raise and lower the window.I could not figure out what the problem was.I hear the scraping noise and the window stops,about 1/4 of the way up! After about an hour of staring at it and trying to figure it out:confused ,I was finally able to force the window all the way up,but it was very difficultad.Time was of the essence when I was doing this because it was getting ready to rain and I wasn't in my garage so I had to quickly put everything back together.The window motor works fine,I think it may be something to do with the tracks that the glass rides in? I saw,what looked like, some adjustment screws on the bottom of the door where the tracks mount to the door.Do you think this needs adjusting or something?If anyone has had experience with this ,I would really appreciate some guidance concerning this issue.I am very puzzled about this.I thought it would be really obvious when I removed the door panel,because the noise is terrible.:ugh
