bob02Z06
Hey everyone,
I have a 2002 Z06 Corvette. It had a few issues lately; I thought I got them all resolved, but I guess I am having a few more.
I will go over the history of recent resolved problems. (within past month and a half)
-thrown code for driver side rear o2 sensor. (found that all were pretty bad looking, replaced the two rear o2 sensors)
-Car suddenly ran like hell on the road. Had a misfire and MAF sensor code. Also shop I took car to found a busted valve spring. (replaced the MAF sensor, spark plugs, valve springs, and the front two o2 sensors)
Car ran perfect and purred like a tiger after this.
-I was driving today, since Washington has some unusually nice weather right now. In my drive my check engine light came on, however my car was still running perfectly. When I got home I held the 4 button and pressed the 1 button 4 times to get to the check codes menu. It came up with p0420 HC, which is a code I have never seen on the car. I am afraid I have a catalytic converter going bad on the driver's side; because all of those o2 sensors are new, the exhaust is on tight.
Car runs very well, but I do not want to cause any unnecessary damage to it. Should I just get both of the catalytic converters replaced?
PS: I will be getting into contact with my friend this Sunday as well since he has a code scanner that will let us know the cat temps and any other valuable information.
Any input is valued, Thank-you for reading!
