B
BaileyMotorSports
We would like to offer the C.A.C members an opportunity to get in on the Group Purchase for the C6 Predator Tuner. Legally, we can not post our price for the unit. So please, feel free to email or call about the unit. We have 6 Units available at our Group rate.
Description:
[FONT=Arial, Helvetica][SIZE=-1]The Predator is a state-of-the art high performance tuning flash programmer, which advances the timing, optimizes the air/fuel ratio and remaps the transmission shift points (in automatic transmissions). Unlike other 'tuners', DiabloSport�s programming is performed in very small increments throughout the entire RPM range, for a smoother, wider and a more predictable power delivery. [/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]Lifetime Warranty! Screen Size that is 300% larger than the competition Quicker programming (takes approx. 2 min.) Custom Files can be downloaded from internet which allows for future updates and customized programming OBD-II diagnostic software (includes live data monitoring of MPH, RPM, IAT, ECT, LTFT, STFT, O2 voltage, timing, knock retard detection, as well as many other sensors Eliminates CAGS (Skip Shifting) on the 6-speed manual transmissions Revised Torque Management Settings for optimum performance User adjustability. the user can set their own parameters - Choose from DiabloSport's performance program, have a custom performance program made for you by a Diablo Tuner, or create your own: [/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]a. Richen or lean fuel mixture[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]b. Advance or retard ignition timing[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]c. Raise and lower shift points in 10 RPM increments[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]d. Raise and lower rev limiter in 10 RPM increments[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]e. Reduce shift duration (time delay during gear change) (+/- 25% and anywhere in between)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]f. Increase or decrease shift firmness (+/- 25% and anywhere in between)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]g. Correct speedometer for gear changes and/or tire sizes[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]h. Turn on cooling fans at lower temps in incremental steps of 1 degrees (for vehicles w/ factory equipped electric fans)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]i. Adjust top-speed limiters[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1]The Predator allows the end user to adjust the following parameters:[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Timing Table 2000-4000rpm (+15/- 20%)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Timing Table 4000-7000rpm (+15/- 20%)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Fuel Table 2000-4000rpm (+/- 20%)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Fuel Table 4000-7000rpm (+/- 20%)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Idle (+ 500rpm / -300rpm)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Speed Limiters (Trucks Only)[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Rev Limiters[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * RPM Shift Points[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * MPH Up and Downshifts[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Shift Timing[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Shift Pressure[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Cooling Fan ON and OFF temperatures[/SIZE][/FONT]
[FONT=Arial, Helvetica][SIZE=-1] * Re-Calibrate Speedometer for Gear and Tire Size Changes [/SIZE][/FONT]
A full description can be found here: *Pricing doesn't reflect group purchase rate*
http://www.baileymotorsports.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=BMS5549C6PRED&Category_Code=corvettec6_engine
Most of you are familiar with the unit, whereas some may not be.
Feel free to send us an email for a price quote!
sales@baileymotorsports.com
Description:
