C6 seat cover replacement instructions?
fvette05
Active member
Iowa
05 LMB vert, 6-speed
I've been searching all over for instructions on how to replace the seat covers on a C6 ('05 in this case). I just got my first Vette (05, 6spd, LMB vert) and all I want to do is replace the seat covers with genuine GM 2-tone covers. Anyone have any instructions or advice?:eyerole
seats
I had mine done at a shop up the road.All you need to do is unzip,remove the clips underneath and pop out the bottom cushion.I know of directions for this on another forum,don't know if there's any on here.I had a pro do it because I needed extra work done,but it's not real hard from what I hear.Watch the air bags though!
Thanks! I've looked on the other forums but will check it out again.
Look under your bottom cushion,disconnect the wires/clips,etc,and lift it off.For the back,you have zippers behind the seats.Just pay attention to all the clips and connectors and you'll be fine.Or just remove the 4 bolts and wire connectors under the seat and remove the whole seat in one shot.
