If you are wondering if your 75 chunk will fit, it will. half shaft u-joints are the same, use the appropriate u-bolts/caps/straps for the side yokes you have and the driveshaft problem can be overcome with a cross joint. a cross joint is a u-joint with 2 different sizes and enables you to mate the driveshaft with the diff. go to a parts store that has catalogs as they will have to find it in the back of the catalog by checking specs on both the 64 and the 75 u-joints. the part number that comes to mind is a precision #372, but I am just guessing, so try and look it up, but if all you find are idiots behind the parts counter, try that number. BOL. Dennis
