California Emissions
Ottawa Ontario
1985 White/Silver Coupe, 2001 Pewter Coupe,Z51,6sp
Still looking for my 6 speed 2001 .... :D
Does a car with RPO NC1 and YF5 - California Emissions, have anymore plumbing or a more complicated system then a non YF5 car? The car is from southern California.
The owner says: Teflon Rings, replaced by GM. What's that all about? Is this to do with the 01's that had an oil burning problem?
Ron ... :confused
If my memory serves me correctly California Emmission C5's all had pre-cats which are small catalytic converters (pup-cats) between the exhaust manifold and the main cats. A total of 4 catalytic converters.....
I think that the only difference between CA emissions and Federal emissions is that there was more testing done for the CA emissions :) Same setup, more tests.
We may both be wrong but I belive Tom is correct. A certain number of cars shipped into California are pulled for extensive smog testing. There is no physical difference in the cars, just the amount of testing.
The CA cars are the same as the 49-state cars. There should be an underhood sticker that says it is 50-state legal, or that it meets CA Air Resources Board standards--that is pretty much the extent of the difference, if any--just the sticker.
That is correct. I got mine from GA and it passed in CA with flying colors.
Rick
Like the others have said, the C5 qualifies as a low emission vehicle. I actually read that in Car & Driver.
What kind of testing do they do in CA? For cars '96 and up in IL, they just plug in the OBDII and if it doesn't throw a code, the car passes. For cars pre-'96, they actually run it on the rollers and take exhaust samples at various speeds from 20mph to 55mph.
They do the rollers, OBDII test, cats, visual check, gas cap.
Rick
Rick
They do all of them? That's very strict testing!
They only do the smog test on a new vehicle if it is not certified for CA. After that, at least for 04 and up vehicles, you don't need testing for 6 yrs, IIRC
What happens if you fail emissions?
Here, if you can't pass by your due date, you can't buy a registration sticker and they'll suspend your plates.:eyerole I'm not complaining but with all the other problems like violent crime in Cook County and a big budget deficit, I figured that emissions wouldn't be so high on the priority list.
