{Callaway} #89-005 in the BFGoodrich drag radial ad
*89x2*
CallawayOwnersGroup.com
Found Z.R. 's Callaway tearing up the track in the "Callaway Archives" ;) Car is QUICK :eek
from the BFG tire ad:
1.77 short times w/ an 11.57 @119 :m
Re: Re: {Callaway} #89-005 in the BFGoodrich drag radial ad
JT ZR-Won said:
Awesome times! Tell me that's not stock :D
Jay
About a year and a half ago I changed the cam and heads, installed an engine management system and larger fuel injectors. The rest of the engine is as it was when I purchased it. The best time with the original engine as received was a 10.93 ET, and best MPH was 126.44. The stock engine, with a lot of tweaking (trial & error) that I learned over the years, was capable of running consistently in the mid to low 11’s with an occasional dip into the10.9’s. The biggest problem is getting the power to the ground. The track has to be prepped properly to help you get those kinds of numbers.
:eek :upthumbs
