gedmeyer
The last time I was out in my '81, I had the Battery and Choke lights illuminate. In addition, the Choke Relay started buzzing while at idle. The Battery and choke lights stay on all the time, w/ the battery light getting brighter w/ rpm. I've been troubleshooting this for awhile and can't figure it out...
I have not changed anything on the car this year, so there is no mods to look at...
-gedmeyer
- Batt. and Choke lights go out with green choke wire being disconnected. When connected, the choke is getting ~5.5V
- The batt voltage measured at the batt is 14.4V. Measured @ the alt, it is 14.75 V. The voltmeter in the dash shows about the same.
- I took the alternator to Advance AutoParts and they tested it as 'GOOD'. I'm not sure if their test checks the other connectors on the Alt.
- With the 2 connector plug disconnected from Alt, the #1 terminal (on the connector side) measures 11.8V at idle. The #2 connector shows 12.2V. Both terminals on the Alt. side show <0.1V.
- With this connector plugged in, the #1 terminal is 17.3V at idle and goes up with RPM. The #2 connector shows 14.4V, steady.
-gedmeyer
