Sensei,
When I replaced the cam the first time, my A/C system was not charged, so I see your concern. I believe that the law (Federal, perhaps?) requires the capturing of the refrigerant agent. So check around for price quotes on this.
Unfortunately, with the condenser out of the way, it is easier to remove the old cam and install the new one. On the positive side, once you're done with the swap, you'll be able to service it with FR-12 which replaces R-12.
I had the L81 computer running when the 268H was installed, and it behaved much like an L82 engine. A subtle overlap at idle, good idle manifold pressure, and it pulled strong with a very flat torque curve. However, I also had Aluminum Edelbrock Performer heads with 64cc chambers which also bumped up the compression ratio (CR).
The 260H is also a good bump stick, but consider researching other brands for a similar cam with more lift or ask CompCams to customize one for you. The 8.2 CR in the cylinders has to be kept for as long as possible and let go as quickly as possible. A total of 0.440" lift (when using 1.52 rockers) is a good lift, but consider finding one with a bit more (i.e. 0.484" on both intake and exhaust called a single pattern cam) or perhaps with the exhaust cam keeping the exhaust valve open slightly longer (what is normally refered as a dual pattern cam).
Just remember that one single modification to the engine won't work a miracle resurection of the L81 engine (remember that the computer is programmed to keep the engine in a particular profile). With the L81 engine, forget about horse power, and go after torque. The computer knows nothing about the torque.
GerryLP:cool
