Ken
Gone but not forgotten
Okay, so it works like this:
As I said, it runs fine most of the time, but every now and then it will run bad, sometimes really bad, with a "fluttering" kind of miss present. Of course, nothing shows up on my datalogs to indicate exactly what is causing this code to be set. I have even changed sensors yet I still have the code, as well as an intermittent fluttering miss. The miss is more bothersome in the engine's sound than in its effect on the engine's performance.
Anybody good at diagnosing or troubleshooting these sensors? ;help
Now, my sensor is functioning, in that I can start the car and it runs, for the most part, just fine. But I do have a constant code indicating an "Intermittent Cam Synch Sensor Failure".As with the crankshaft sensor, the ignition module sends a reference signal to a Hall-effect switch in the camshaft sensor. A permanent magnet, attached to the camshaft sprocket, passes close to the sensor once each camshaft revolution (the camshaft rotates once for every two crankshaft revolutions). As the magnet passes beside the sensor, the Hall-effect switch is activated by the magnetic field, and its transistor turns on to ground the ignition reference signal line and pulls its voltage low (0-0.1 volts). The camshaft sensor "sync" pulse is received by the ignition module as piston number 1 (and 4) reaches approximately 25 degrees ATDC on the power stroke. The camshaft signal out is also sent from the ignition module to the ECM.
