Homework
Hi Martin, Look I'm a new Z owner also. Got mine this past Dec. I just put the front end up on jack stands, I don't have ramps yet, and just took out the drain plug & let it drain. Now there will be oil left in the cooler & lines which will not all come out. I have been told by the experienced Z owners here that what is left in the system is not a concern. If you think about it the couple of qts left are not significant. Just don't try to fill the filter before putting it on unless you have fast hands. The fact that some old oil remains is disconcerting but in the total picture what can it hurt realistically. Just get some M1 & a good filter & have at it. You might want to check out the info on the ZR1netregistry & even join up. Good luck, Tom.
