norvalwilhelm
I spot tested some of the roller springs I got with the heads just now and they far exceed what the cam calls for. The comp roller cam calls for 440# at .600 lift and I have 700# at .600
I then took the dual springs apart and tested only the single outer spring and got 210# seat and 436# at .600
That is right in the ball park for the cam BUT can I just run a single spring. For safety in the even of a broken spring I though dual is like a spare tire. I won't drop the valve, rev's would be down but no dropped valve. Also harmonics? While these don't have damper springs they are duals and interference fit.
Can I safely run a single spring or am I stuck with buying new springs?
