brewster1943
New member
My 1987 vette ran perfectly until one evening at 7-11 it just stopped. Finally got it home and pulled the distributor cap. Found plastic parts almost shredded, so I cleaned it out and replaced the ignition regulator and other parts inside the distributor. Would not start. And that's when the headaches began.
New distributor, cap and coil. I've replaced the throttle sensor, have new plugs and wired, but to no avail. When I start it cold, it will not idle until the coolant reaches at least 160 degrees. I have to play the throttle to keep it running until it gets to that temp, all the while belching and backfiring. Once it it there, it will idle but the idle speed ranged from 500 to 800 rpms. Once I have the engine up to around 1600 or 1800 rpms, it seems to run smoothly. I've adjusted the timing, set the throttle sensor to the correct voltage, plugged all the wires back in, and still have the problems.
My next step is to replace the IAC. My question is: do my car's symptoms sound like a bad IAC? And second, can the IAC be replaced (removed and a new one installed) without taking the throttle body off? I don't see any way to do it, but thought someone might know a way. Any advice would be appreciated!
