Rich96c4ce
- Joined
- May 24, 2003
- Messages
- 157
- Location
- Annapolis, Maryland
- Corvette
- 1996 LT1 Collector Edition Coupe
'96 LT1 Coupe:
I have replaced the intake manifold gasket set using the Right Stuff.
I have replaced the valve cover gaskets.
I have replaced the oil filter adapter gasket and o-ring.
I have tightened up the oil pan bolts.
Still, there is an oil leak near the rear of the engine. When I have finished a quarter mile, there is burning oil smell and smoke coming up from the rear of the enigine, directly above the oil filter. That is the only time that I get any evidence of an oil leak. I presume that it is because of high oil pressure resulting from the high RPM operation.
Any suggestions?
Could it be a bad oil pressure sensor, or oil pressure sensor fitting to the block? I can't see where it is, but at that high up on the block, I don't see oil on the surface of the block's bell housing joint.
Any suggestions?
