eoseitz
I'm not quite sure how to describe this. It's as though the car shimmy's back and forth. The car also pulls to the right pretty bad. When coming to stops I also hear a popping sound. I can't figure out if the sound is coming from the front or rear. I can feel the pop in my drivers seat though. I just replaced all the u joints two weeks ago, so they should be good. I'm leaning toward ball joints or wheel bearings. I know the wheel bearings need greased. I greased the outter front drivers side when I had the car on the lift doing the u joints.
Could this maybe be a combination of problems. My tires are definitely in need of changing. I'm thinking maybe broken belts. Luckily I have a front suspension rebuild kit. That should take in everything except the wheel bearings, pitman arm, and gear box.
Unfortunately, I was in a car wreck and my daily driver is down. I have to drive this daily, so I can only repair a bit at a time over the weekends. Any suggestions as to what I should repair first? I'm definitely thinking new tires this weekend. However, I'm concerned about tire wear with the allignment issues.
Oh as a side note, I have a new leaf spring on the back. Replaced it about two years ago. It still looks like its in great shape. I need to change the bushing though. I have those as well.
Thanks for any responses.
