J
JamesRS2000
This has happened several times now. If I disconnect the battery to make a change on anything and reconnect the battery, the car will not start.
The car is an 84 crossfire Vette. I have made several changes that required me to disconnect the battery and each time I reconnect it I spend about an hour trying to get the car to start again. Eventually the car will just start, but I need to find out why it is doing this.
The car will just not fire any fuel from the injectors, it will crank just fine but there is no spark and no fuel.
The car has had this problem since I purchased it about 4 months ago and I have been upgrading parts that were in need of replacement anyway, but I have not as of yet stopped this problem.
So far I have replaced these items: Distributor, O2 sensor, Plugs, wires, cap and rotor, MAP sensor, fuel pump, fuel filter, and throttle bodies re bushed.
The key fob that I have says Amenity and does not look like a Corvette factory fob, but I think that I still have the factory Theft Deterrent Module.
You guys have any suggestions?
James
James
