larry bud
1986 Vette, been running fine, but I noticed that the clutch was squishy and discovered the clutch master cylinder was leaking, so I bought a new one. I've had this car since '92 and have replaced this part twice before, it's no biggie.
Unhooked the neg battery terminal, remove the clutch master cylinder, put the new one in, bled it, buttoned everything up, and now the car won't even turn over.
At first I thought it might be the clutch switch on the pedal, where it would think the clutch wasn't depressed, but that's not it. I didn't disconnect anything under the hush panel, and I double (and triple) checked to make sure nothing came unplugged, specifically the connection for the VATS for the key.
I'm at a loss as to what I might have done.
