Just was wondering if anyone has knows what a good carb and manifold would be for my 64 coupe. Engine is 68vette,327-350HP, 4-sp, headers/sidepipes.,otherwise engine is stock, except it is freshened up.Also when i replaced timing chain,with alignment dots straight up and close to perfectly vertical with cam and crank centerline, my damper is now like 6deg.btdc. New damper and old one were compared and the old damper didn't appear to have slipped, and old chain and sprockets are identical. Engine was at tdc before work was started, but for some reason now, damper does not read tdc on tag. Just don't get it. Would like to use a timing light. What would initial timing be anyway for aforementioned engine, around 8deg? Thanks!!
