M
MrCrowley
Well if you wanna handle some real power carbonfiber shafts are the way to go. Here are a couple of pics before I install them this weekend. There are also some body panels in the picture that I repainted. I got bored at work so I stripped, and repainted them. I love being able to actually paint my car for no money at all. And black makes it easier.(no blending required)
In the pictures are carbonfiber half, and drive shafts. They have billet aluminum ends, and heavy duty spicer ujoints without grease fittings. The billet ends, yolk, and the ujoints are cryoed for extra strengh. Then I got a pair of billet steel spindles to boot. I am now ready to do some 4-5k launches with slicks, and I will not worry. Once I get the old ones out I will weight them to see what the difference will be.
If anyone is interested in the shafts I can get the whole package for 1200.00 bucks for all three shafts with the cryo-ing. And the whole kit with the billet spindles will run about 1895.00. Just see my profile, and email me if your interested.
Here are some advantages of carbon fiber.
Lighter than steel or aluminum.
Three times torsional strength of steel.
Torsional spring rate allows better tire hook-up.
Torsional spring rate allows smoother shifting.
Less shock load to the differential.
Eliminates or dampens high speed vibrations.
Reduces transmission and differential breakage.
In drag racing applications - a better 60 Ft. time.
ET's have been lowered in some cases by as much as .120.
In stock car racing better control out of corners is the result of the torsional spring rate.
In road racing smoother shifting and better durability of transmission and differential have been reported.
Both steel and 7075 Billet Aluminum yokes are available.
A much greater safety factor - carbon fiber will return to a fiber and not create shrapnel under the car, as would aluminum or steel shafts.
And this is extremely important on a vette as it won't destroy the underside of your car. (e.g. trailing arm, abs sensors, and the floor)
