Carpet
caddy
Houston,TX
2005 C6 LeMans Blue
I have a 94 coupe and the carpet behind the seat up against the back and the insulation keep falling down, it's black and I would just as soon replace it, can anyone tell me where I might buy that one piece of carpet?
thanks
:pat
If it's behind the seat, you could just go to any place that sells car audio and they'll have different types of carpet that you use to cover a subwoofer. Very inexpensive to. You'll just need to buy a can of 3M adhesive and it should work fine.
Jay
the reason why it keeps falling (most likely) is the rings that hold up the carpet are ripped. All you really have to do is buy metal rings and some thick thread. Sew the rings into the proper places on the carpet (there are 4 of them if i recall correctly). after that, all you have to do is take off the black plastic in the back... you will see the four studs sticking up to put the carpet back. By doing this, you will fix the problem permanantly. Replacing the carpet could get you in the same situation anyway, because the design isn't that good.
Fantastic!!! thank you so much.........I'll take care of that,..
thanks again
