carpet
  • Thread starter Thread starter dramo1
D
dramo1
should i put in new carpet with or without mass backing..what is the difference
thanks
thanks
Mass backing is what came in the corvette from the factory......Poly backed is not as thick and I hear that it, (it,being the poly)wears out faster and the inside will be hotter and you will have more road noise. Of course you could install Dyna-Mat and use poly......I think the cost diff between the poly and the mass isnt worth it as the Dyna-Mat is expensive
Just my .02
i adgree with SoLow. And the best thing i did when i had my door panels off to do the inner and outer window seals i put some sound deading in them and the cabinet is alot better! now for behind the seats in the cargo area.
