7
72VETTETORONTO
how do i find out if the casting number is correct on the block ;is there a website to go to ?
If you want to check "matching numbers" then the casting # is NOT what you want. Check the "stamp pad", a machined surface on the block in front of the passanger side head. Should be two numbers stamped there. Write those down and then look at the VIN. One of them should end with the last six digits of the VIN. If so you may have the original engine. If not, the engine has been replaced.72VETTETORONTO said:Thanks so much looks like the number is a match but i do not think its the original motor.
