Bluemill
To LLC5 and the rest of the Corvette GURUS, my car appears to be fixed after putting on the 2001 cat/pipes assembly. The part fit like a glove, despite the different part number for the 2 different year coupes. So a 2000 coupe can use a 2001 coupe H pipe. Not an easy job to do on jackstands, and alone. Used a small aluminum jack to squeeeze that sucka into place.
Got my Commondebt of Massachusetts safety/emissions sticker for the last time, in that at 15 model years old emissions are not a sticker killer! Yeah for that.
I come home with emergency flashers going I went to toot the horn in celebration....... and that puppy doesn't work. Now I know it worked for the inspection, so I must have popped #11 fuse under the hood?? Nope, it's OK. If you heel the wheel over, right or left, it works. I know it's likely a column ring thing, BUT I hope it has nothing to do with my aggressive spraying of white lithium grease through the firewall grommet-sleeve to stop the steering moan. Saw that one from C4C5 Specialist-" EL SUPREMO" of Corvette Technicians. Paul is the man!
Best always,
Bluemill
:cool2:
Best always,
Bluemill
:cool2:
