TODD L GRIFFITH
- Joined
- Jul 12, 2001
- Messages
- 1,120
- Location
- Middleboro, MA
- Corvette
- 99' MR Coupe, 04' Silverado 03' ZO6 Sold
Hey DanHammer, Like that yellow coupe with those rims
The BAD side to simulators, is that this will throw off your fuel trim calculations.
Terry Holtz said:Let's resolve this debate because alot of cheap horse power is waiting for us if the converters can be safely removed. Thanks.
Some of you are either:
a. confusing the front sensor pair with the rear pair, or
b. guessing, but not labeling your response as a "guess".
TODD L GRIFFITH said:Yes, the O2 simulators would trick the PCM into thinking that the cats were still installed by producing a .450mv signal back to the computer. The simulators are to go in place of the rear O2 sensors behind the cats. The simulators can be purchased through Mid America for about $150.00. The link to the online catalog is www.madirect.com .
long tube headers, high flow cats and an x-pipe is where alot more horses are unleashed.
This says that the rear O2 sensors do provide the PCM with info. so that your STFT's and LTFT's will be thrown off with simulators.
TODD L GRIFFITH said:Tuning to offset the +/-25% disparity in other than normal voltage readings between the front and rear O2's would be needed, especially if you are trying to make power and get fuel. The PCM will try to lean the mixture during good emissions. This is what you don't want based on the fixed .450mv signal from the simulators.
