Paul Higg
Can anyone tell me what this is all about? I had my emissions test done today and the NO was a little high. The guy that did it was a Vette guy and he said there could be three reasons. The engine may be running too lean, possible bad EGR, or the catalytic converters going bad.
Now this is where I need enlightenment.
He said something about the cats should be hotter on shut down that when they were running or SOMETHING like that. Can anyone give me the scoop on this?
Thanks.
Paul
Oh, Junk, today I removed and cleaned the IAC, it was very sooty. I also removed and cleaned the EGR and it was a disaster in there. It took almost an entire can of degreaser to clean out the gunk in there. Then I removed the air bridge going to the throttle body and opened the butterflys and looked inside and it was full of black gunk. So I started it and opened the butterflys and sprayed some carb cleaner in there while it ran. I was told this would not be a problem but I would have to pour gallons of the stuff in there to clean it out. Someday I might remove it and clean it. 90,700 on the clock, LT1.
Thanks.
Paul
I drove JimmiJams car to Charlotte and back after doing the work on it,I had to go anyway so I drove it just to make sure it wouldn't trip a code!!
