- Thread starter
- #41
firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
if you came to the same conclusion that I did with a tube lenght of 7.5 inches...now that is truly amazing....I used your alternate method...at any rate...the numbers may not be perfect, but are certainly in the ball park....if I get in the ball park, I can always find my seat...HAHAhenny496 said:Hello Herb
Using the 60% value on the shock you should be about 13.75 in center to center of shock eyes at ride ht ( 11.5 compressed plus 2.25 in)
Your sprngs are 10.125 extended with 8 spaces @ .8125 which gives a total of 6.5 inches. If your spring was bottomed out that would be 10.125 - 6.5 = 3.62 inches. Using 60% of 6.5 inches that is 3.9 inches
3.9 plus 3.62 = 7.52 inches @ ride ht
10.125 - 7.52 is 2.605 inches
The shock extended is 15.25 and at ride ht is 13.75 in which is a difference of 1.5 in
Is there a rubber bumper at the bottom of your shock travel? That would be a cushion block on the rod
I know Koni's have a bumper block of at least an inch. If you do have a bump block, that would have to be factored in . The bump block helps the shock on bottoming out . 3.75 inches does not sound like a lot of travel
take care
Tom
also make sure you did not count 1/2 a coil in your dimensioning( end of spring)
