jimbil208
Hello
I have a 1982 collectors edition.
The check engine light came and it also is not runnung as it shoule.
I ordered and recieved a cable to plug in and software to run on my laptop. As it does not work I called the copany about 4 times.
On my connector under the ashtray I have grd on pin A and 5 Volts on pin E.
That is about all I know,other than the software does not run.
On place I saw u can connect pin A to B and turn key on and it will blink the code out.
That does not work either. Does anyone know whick way I should turn????
Thanks,Jim
Thanks,Jim
