like2drive
I'm in process of installing the center cluster (which has the temp, oil, elec, etc gauges). When I start the car to see if the gauges are working properly, I noticed that the oil pressure gauge does not. The needle will "rest" between 60 and 80+ lbs. When the ignition is turned on, the needle jumps on up past 80 as far as it can go.
Could this be a case of "reverse polarity"? If so, how do I fix it? Or, could this happen if the rear printed circuit is shorted out? (it's "aged")
My battery gauge would not work earlier, but "jiggling" the connector on the rear got that working. The small, flat , copper "tabs" that the connector plugs into, are very flimsy. However, I don't believe the problem is that because the needle moves when the switch is turned on.
( PS: Does this sound like something a sane :crazy person gets into when swapping transmissions ? ....long story) thanks in advance, Jim
