well actually some manuf. do specify differant intervals provided you run a synthic oil, Porsche, and Caddy's just to name 2 ( 7500 mile interval ) Mobil 1 still recommends 3000 with their super-syn oil, and Amsoil anywhere from 7500 - 25,000. The other statements ie: small oil leaks after converting also has some merit, BUT if the synthetic had been stuck with in all likely hood the oil leak might have disappeared. One of the many advantages of todays synthetics is their abaility to clean the engine, and this may sometimes result is small leaks, as the seals ( and engine )become cleaned, and reconditioned, the leak is generally re-sealed ( assuming no carbon etc buildup was simply blocking an existing leak).
U.S. is the only primary place with a 3000 mile oil change interval, the same oil's and vehicles sold here, has a 6000 mile interval in europe.
Any good synthetic will actually save you money in reduced oil changes AmsOil, RedLine, and Royal Purple. Of course i am a bit biased towards AmsOil !!!
But i do run it in my '87', with 92K and my 97 Intrepid with 147K, no oil leaks in either vehicle ( and the Intrepid was changed over at 90K, ran dino oil from the day i bought it with 21K on it)
Of course as mentioned in earler posts The filter is of major concern, but the oil plays an important roll as well, i would not attempt to take ANY dino oil to the 10K to 15K mark under any circumstance, but i would with a synthetic ( also included in the Dino catagory would be the Dino/synthetic blends ie castrol etc )
http://syntheticoiltech.com/oil/lkraus/
