- Moderator
- #1
KANE
Moderator
- Joined
- Mar 2, 2002
- Messages
- 3,241
- Location
- KY
- Corvette
- Dark Blue 1982 Trans Am(s): Polo Green 1995 MN6
Posting some of my thoughts and experiences with changing the WOT shift points. My set up makes maximum power at 5.3/5.4k rpm. To make full usage of the band, I need a WOT shift at about 5.4/5.5k rpm when warm.
Baseline:
The 82's 700R4 would shift hot at 5k rpm, warmed up at 5.2k and cool at 5.6k out of first gear. The transmission has been rebuilt at some point in the past and has less than 70k miles on it. FWIW- I have a 325hp/375tq motor and a 2.87 rear gear.
Enter the B&M governor reprogramming kit... six weights and six springs.
OEM Weights and Springs:
My 82's factory governor has two "e" inner weights. One has an a capital E (12.055 grams) the other has a backwards capital E (12.1540 grams). The heavy side had a factory purple (heavy weight spring) and the light side had the factory white spring (light weight).
Handful of Results:
Factory E weight (12.050g), Blue B&M spring
#3 B&M weight (11.155g), Yellow spring
~~~~~~5.8k+ (let off to protect the engine) 1-2
~~~~~~5.6k 2-3
#2 B&M weight (13.080g), Yellow spring
~~~~~~5.3k 2-3
#2 B&M weight (13.080g), green spring
~~~~~~5.7k warm; 5.6/5.5k hot 1-2
~~~~~~5.k 2-3
Next up-
I am going to test a few more combinations and post them.
I have this combo in to test as of now... I would like to see the 1 gram reduction increase my rpm at WOT by about 500rpm. 2 grams made a big difference in testing the B&M weights (weights 2 and 3), looking to see if a 1 gram reduction gets me where I want to be.
IN CAR
Factory E weight (12.050g), Factory White spring
#3 B&M weight (11.155g), Factory Purple
Seems to me the GM purple is stiffer than the B&M purple... so going from GM purple to B&M blue feels like two steps down. This might come in hand later.
Baseline:
Handful of Results:
~~~~~~5.6k 2-3
~~~~~~5.3k 2-3
~~~~~~5.k 2-3
Next up-
IN CAR
